| | | Forums66 Topics128,038 Posts1,055,584 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 | I'm looking to buy a mig welder mostly to do the floors and body panels. I never mig welded and don't know anything about it. Home Depot has a Lincoln Weld Pak125HD for $419 & a Lincoln Electric Handy mw for $286 - includes gas reg & hose,the 125HD does not.I want to save money ,but at the same time need a good easy to use welder.I appreciate any advice as to what features to get , what size to get, what will be easier to use, what brand. I have stick welded on a good day, can braze & solder.
Keep movin' forward.
| | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | | | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 |
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Spend the extra for gas. And practice before trying the floor pans or you might end up paying a pro to fix your mistakes. Ask me how I know. | | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | I second what jomichael said about practice. Welding in the floor pans and other patch panels can be tricky and you can damage them. I also agree with spending the extra for the gas. I'm working on installing patch panels in my cab right now and I just tack up a little everyday, not wanting to burn a hole or warp the panels. I have a Miller 135 unit.
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I found that cheap a$$ harbor freight wire feed worked great for my cab corners and other light gauge needs. Its so dirty that all I could do is hit one spot at a time and then while I'm wire brushing and cleaning the surrounding area getting ready for the next 1 or 2 second session its cooling down  On the plus side I worry very little about too much heat build up and warping... on the down side I go through wire brushes a lot faster....
| | | | | Joined: Sep 2010 Posts: 25 New Guy | | New Guy Joined: Sep 2010 Posts: 25 | Thank you, guys, I appreciate the wisdom. Sounds like the gas makes a better weld, and practise on scrap is a very smart idea.I looked up Miller and see Millermatic 140 - must be the next generation from the 135 - I'm leaning that way.Thanks for the warping tip-I'll take all the tips on how to weld floors and body panels I can get. I've been pouring through the posts in this section. Thanks again.
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Dave, thanks for posting that link. Jon, here's another that may give some helpful hints on welding sheetmetal.. Welding in Patch Panels . | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Jon, here's another that may give some helpful hints on welding sheetmetal..
Welding in Patch Panels Geez, that guy knows his stuff. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Dave, thanks for posting that link. Jon, here's another that may give some helpful hints on welding sheetmetal.. Welding in Patch Panels . That's the post that started me thinking maybe as a total novice to body work I could actually do this and the next thing I knew I'd decide to attempt doing my cab corners and that exact patch on both my fenders. MP and C... With all the visuals and the do's and don'ts you provide you kinda remove the "what if's" that were holding me back I don't know whether to cuss you out or thank you for getting me started down this road.
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I don't know whether to cuss you out or thank you for getting me started down this road.   Glad I could help! | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | JonGilroy, I just bought a Hobart Handler 140, and it works well. (My old Daytona MIG died after 20 years.) I tried the gasless wire, and it is sloppy, leaving splatter all over. Back to ArCO2. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | use .23 wire with ArCO2. stitch is important. and like they say practice, practice,....... .
daren | | |
