1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#843245 04/12/2012 5:21 AM
Is is possible to have my original 1948 speedometer rebuilt? I'm leery of the new aftermarket units.
Yes. If you have an old time speedometer shop still around, they can do it for you. Local shop rebuild mine about 10 years ago. Still going strong. Now they are out-o-business.
Kurt
If you are reasonably handy, you can do it yourself. Most all cosmetic parts are available from vendors and the speedo/odo mechanism is very simple and rarely worn out or broken. Main thing when rebuilding or restoring the mechanism is to completely disassemble and clean out all the old dried up grease and replace with new grease.
Here is a photo of the speedo out of my '52 that I restored.
Just in case you want to give it a go at reparing it yourself, this Tech Tip may give you some insight.
- Lonnie
My '54 3104
Ed
