| | | Forums66 Topics128,134 Posts1,056,403 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Hello all,
I'm new here so please forgive me if I posted this in the wrong question, or if there's already a thread for this (I did search for one).
I was doing some disassembly on my '46 GMC, and found there is a small light on the back side of the dash that shines through a slit in the middle of the dash over the switches and cables in that area. I didn't know this bulb was there, and am wondering if anyone knows what this is called, and how it operates? I'm wondering if it's wired in with the dash lights, or if it only works with the switch it's wired to under the bottom lip of the dash? It appears to be factory.
Also, is the dome light wired to work with the headlight switch?
Any help on how it was wired and how these lights worked stock would be greatly appreciated.
While I will be rodding my truck, I think these are neat features to retain to work as they would have originally.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a 46 chevy it is likely the same. The one through the slit in the center top is the high beam indicator light. It goes to floor high beam switch. The dash lights go to a switch on the bottom right of the dash near the steering column. There is another light over the choke and throttle knobs. That one is on the other side of the switch under the dash. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Send me an email address and I'll send you a wiring diagram for 46 chevy. [email protected] | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For future reference: most people have their email address in their Profile. You can find their Profile (View Profile) by clicking on their name at the left of their post.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Thanks GWWirth for the information and wiring diagram. That's a huge help. The bulb I'm referring to, because it's connected to a switch, looks more like the Ignition Lock Light and Instrument Light Switch referred to in the wiring diagram you sent.
Can you help me with the comment under the dome light in the diagram? I can't read it, but mine does have a dome light right behind the drivers head.
Thanks again. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Ahh you must have a 461/2 - 47 or an AD Advanced Design. The truck I have does not have a dome light. The wiring diagram I sent would not necessarily be the same. If I am right you have a one piece hood that is hinged by the firewall. Mine is hinged down the center. 1946 and 1/2 is when the AD's came out. They ran till 1954 I think. I had a 53 years ago. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | No, I don't have an AD. It is a '46, and is the same body as yours except for the grill and different hood sides.
The interior light on an AD is in the middle at the back curve of the cab above your head. My interior light is almost directly behind the driver's head. My truck is definitely the "Art Deco" series.
It may be because it's a GMC, they had several features that the Chevs didn't in these years. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my 46 GMC was the same as a Chev, as Gene says, the one behind the dash louver is to light the dash controls, and the switch there is a 2 way that powers either the "Instrument Lights" [gauge lights] or "Ignition Lock Light" [controls] - a dome light was standard on panel bodies only but may have been optional for the pickup cabs, or yours was added by the dealer or original owner
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
