| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | So im trying to put a engine fan in my 53/64 truck for proper cooling. I have a few questions on trimming the fan because i think it would be the easiest way to make it fit. My first question is, in order to clear the radiator i trimmed down the front of the fans clutch. Will that cause a problem, i wouldn't think so but just thought id ask. My second question is the fan blades need to be trimmed about a 1" from the tips. If i cut the tips of the blades off will this cause balancing issues? or any kind of issue? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | modifying a fan in any way is taking a big chance on making a hole in your hood or killing someone, find a fan that fits or get an electric pusher in front of the rad
Bill | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Ya an electric fan was kinda what i was thinking of getting, just thought i would try saving the old fan first. Is their a certain size fan i should try to get or would a single electric fan off of a car do the trick? | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | I yanked a big electric fan off a mid 90's T-Bird. I've got a high compression 327 and that fan combined with an aluminum radiator cools it just fine (even when I lived in Phoenix). The fan is two speed. I have the high speed connected to a relay, operated by a thermal switch in the intake manifold. The low speed is connected to a 3 way toggle switch. Power will only make it to the high speed circuit if the toggle switch is in the off position. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Move the radiator forward, use electric fan or find a "thinner" clutch fan. Trimming is not an option, out of ballance= explode per red58 post.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I agree get a electric fan, it will work way better & safer too.....
