| | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | I have the Offenhauser, am considering the headers, I have heard the Offy needs some modification to work with the Fentons, what needs to be changed, exactly? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The mounting flanges are different thickness. Just use a file to get them the same. Also when you put them on the engine you will need to grind a little off the bottom of the intake manifold. Mr. Offenhauser and Mr. Fenton probably didn't speak to one another very often.
There is enough alum. there to grind, just take a little off at a time.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I had to grind on the mounting flanges, but not on the bottom of the intake. You'll need to do a dry fit to see where you'll need to grind. I would advise eliminating the bolts and use studs instead. Also, take the 2 alignment dowells at the ends of the heads out and replace them with studs as well. That will hepl with aligning the exhaust and gets a bit more clamping force on them as well. You may also consider eliminating the factory mounting clamps, as they do not work very well with this mainifold combintions. I ended up making my own from 1/4" stainless after fighting leaks. I'll try to get some good pix of my setup posted tomorrow.
Bill Burmeister | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | When I had this set up on my 1 ton, I had to grind the flanges, and a little off the intake. I used my secret weapon, the 4" angle grinder. For the aluminum, I just used an fibre sanding disk on the grinder. I had expected more drama, but it was an easy process. The worst part, was trying to hold everything up at once, and putting the bolts in. I never thought of using studs, as Bill suggested above. That's a good idea! | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Same here, the grinding. Mr. Fenton didn't get along or speak to Mr. Edelbrock either. Thank goodness there was a lot of meat so that they could clear eachother. Edelbrock/Fenton 1 Edelbrock/Fenton 2
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Clamp the two manifolds together before attempting to install them. This should be a lot easier. | | |
