5 members (papas52, Bills Auto Works, Napco Man, Shade Baby, LAROKE), 171 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#843046 04/11/2012 11:12 AM
Hey guys. Need some quick advice.
Looking at buying my first truck. The link below shows a pic of the driver side door jamb. I do not see a tag with VIN. It is a 1951 Chev truck. I will talk with seller tomorrow. Should I be concerned? He says he has title? thanks
http://s848.photobucket.com/albums/ab41/...8-44-49_651.jpg
_________________________
1951 Chevy 3100
Ex Hall Monitor
Ex Hall Monitor
Most states used the engine number through '55.
How do you know it is a 1951 truck? From the appearance of the truck or from a registration or title or from what the owner/seller has told you?
You photo-link does not work.
50% of my four 1954 trucks had original titles/registrations using the vehicle ID and 50% have original titles/registrations using an engine ID (both ID locations were used in two states, VA and WA).
The main thing to be concerned with is what ID is on the title.
The next thing you have to be concerned with is if your state looks at the IDs on the truck when you register it, especially if your state looks at the cab ID, which you say is missing.
Nonetheless, if the title/registration matches the ID on the engine, you will probably be OK, no matter what state you are in. When you see what the owner has, you could then contact your DMV.
Ok. Thanks. I will check engine code and Title. Heres link to picture
http://s848.photobucket.com/albums/ab41/malibu67/
1951 Chevy 3100
The VIN tag appears to be attached to the door jamb. What numbers are in the box?
I added closeup shot of the door jamb on photoshop album. Looks like weight info only. No vin. I will look at truck tomorrow and check engine. Looks original engine. Where on the box is the VIN/serial numbers located?
1951 Chevy 3100
At the very bottum of the plate is you vin number. It's cut off in your picture.
Here's what it should look like:
http://www.classicparts.com/1950-Door-Post-ID-Plate-Chevrolet/productinfo/33-012/
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
You sir are most helpful. With some luck, by tomorrow this time, i will my next project.
1951 Chevy 3100
Here is a 1951 plate. It is different from 52-53 and it is different from the 47-49 plate and the 1950 plate.
It would be nice to see a clearer photo of your entire plate (the ID-code and GVW and HP values).
Bought the '51 this morning. posted new link in general forum:
"New member - bought a '51 Chevy today!"
Title number ID matched the number on door jamb tag
thanks for your quick advice.
1951 Chevy 3100
