8 members (John Dlugos, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53, Buckeye998, Chip O),
192
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Hey guys. Need some quick advice. Looking at buying my first truck. The link below shows a pic of the driver side door jamb. I do not see a tag with VIN. It is a 1951 Chev truck. I will talk with seller tomorrow. Should I be concerned? He says he has title? thanks http://s848.photobucket.com/albums/ab41/...8-44-49_651.jpg_________________________
1951 Chevy 3100 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most states used the engine number through '55.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How do you know it is a 1951 truck? From the appearance of the truck or from a registration or title or from what the owner/seller has told you?
You photo-link does not work.
50% of my four 1954 trucks had original titles/registrations using the vehicle ID and 50% have original titles/registrations using an engine ID (both ID locations were used in two states, VA and WA).
The main thing to be concerned with is what ID is on the title.
The next thing you have to be concerned with is if your state looks at the IDs on the truck when you register it, especially if your state looks at the cab ID, which you say is missing.
Nonetheless, if the title/registration matches the ID on the engine, you will probably be OK, no matter what state you are in. When you see what the owner has, you could then contact your DMV.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The VIN tag appears to be attached to the door jamb. What numbers are in the box? | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | I added closeup shot of the door jamb on photoshop album. Looks like weight info only. No vin. I will look at truck tomorrow and check engine. Looks original engine. Where on the box is the VIN/serial numbers located?
1951 Chevy 3100 | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | You sir are most helpful. With some luck, by tomorrow this time, i will my next project.
1951 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a 1951 plate. It is different from 52-53 and it is different from the 47-49 plate and the 1950 plate. It would be nice to see a clearer photo of your entire plate (the ID-code and GVW and HP values). | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Bought the '51 this morning. posted new link in general forum:
"New member - bought a '51 Chevy today!"
Title number ID matched the number on door jamb tag
thanks for your quick advice.
