5 members (Phak1, Southerntruck, NJC, Guitplayer, moparguy), 89 guests, and 1 robot.
Topics128,157
Posts1,056,877
Members48,458
#842682 04/10/2012 1:25 AM
0
0 Offline
Just bought a long sought after c30 with a 292...Question on wobble of crankshaft pully - also where can I find the specs on this truck...such as tire size & wheels. Thanks
You can just google for specs.You may just need a sleeve on the crank snout or it's possible the pulley is worn too much. The sleeve is an aftermarket item and a pulley may be found on ebay.
Drew
0
0 Offline
My guess is to replace the Harmonic Balancer? Isn't the sleeve the solution of a leaky front seal?
m
No. It's called Speedi-sleeve. If it's that bad replace the balancer or have it rebuilt. www.damperdoctor.com
Drew
0
0 Offline
Damperdoctor is the meal ticket..finding this balancer locally or on line, is a bit of a challenge...Thanks for your help on this...
