1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, I made a big mistake I bought a new set of ACDelco Spark Plugs P/N: 506C GM# 12043764. I took a picture of the wires when they were connected a while back when I was painting the engine. In the new wire set 4 of the wires are the same length and the other two are almost the same length. Below is the only unique identifier on each plug 2 Wires say D.E.E.D 82 Wires say D.E.E.D 71 Wire says D.E.E.D 11 Wire says D.E.E.D 4In what order do they go installed? Picture of Old Spark Plug Wires Connected
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | When faced with these types of problems, My guess would be in the order that fits best...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | good advice, CASO And, when I asked this question several decades ago, the replies were an ah-duh moment for me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes 1-5-3-6-2-4 With #1 being the lead on the cap that the rotor points to when you have the #1 cylinder at/near Top Dead Center. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Tim, I don't think that is what he meant. I believe he was referring to the markings on the plug wires as the order. Correct me if I'm wrong mauricioaglr.
Also I would cut the wires to the best suitable length and re-attach the plug ends as in a universal set so they would look proper. The hell with what it says on the wire. | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Thank you, I will give it a shot.
