11 members (Buckeye998, treegrower, carbking, dt235sd, Phak1, Rusty Rod, Gdads51, Bill Hanlon, 68ironhead, GMCJammer51, 1 invisible),
379
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, does ACDelco still make a 6 volt distributor and cap and ignition coil for a 235 engine? If they do does anyone know the part numbers and where I can buy them.
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mauricioaglr, firstly we need to know what year 235 you're asking about, the caps changed in the early fifties. I tried to find out by looking at the online AC Delco catalog, but it only goes back to 1966 | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | I have a 46 truck but it does not have the original engine, I believe its from a 58 chevy, the engine number is in the picture below. Engine Block
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mauricioaglr, that picture is of the casting number for the cylinder head, not the engine identification number which is stamped into a machined pad right behind the distributor. I did some more research, and the numbers I came up with are: six volt coil, AC p/n U520 twelve volt coil AC p/n U505 early distributor cap, 52 and older AC p/n D301A late distributor cap, AC p/n D307, hope that helps. | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Thank you, the engine number shows as FII27J is there a website where I can find out what car this engine is originally from?
| | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | My distributor cap is D301A do you know the part number for the rotor?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mauricioaglr, 52 and older p/n D400 53 and up U406, in the future could you please make a list of all the numbers you would like, hope that helps. | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Thank you, I will, I am making my list so I don't have to ask twice.
| | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hy mauricioaglr, 52 and older p/n D400 53 and up U406, in the future could you please make a list of all the numbers you would like, hope that helps. I cant find delco part number U406 for the rotor for my 58 235, anyone know the part number?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Standard makes the ignition parts around now, see here for 58 235 Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Thank you for the reply, but I really want to find the ac delco part number
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You guys are tring to find part numbers for 60 year old engines. Delco probably quit making them 30 years ago. All the ignition replacement parts are avalable from many of the after market vendors but they taint gonna be AC Delco.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Delco parts are found in the Delco catalog, doesn't mean you'll find them in a store .... the U406 rotor fits 1965/66 International trucks  .... what difference does 6 or 12V make to the distributor cap and rotor? are you building a 'show quality' 46 restoration with a 58 engine? Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Delco parts are found in the Delco catalog, doesn't mean you'll find them in a store .... the U406 rotor fits 1965/66 International trucks  .... what difference does 6 or 12V make to the distributor cap and rotor? are you building a 'show quality' 46 restoration with a 58 engine? Bill U406 says its for a 65/66 international but if you do a cross references to napa part rr161 which is the rotor for a 58 235 it says u406. I try to use delco parts whenever possible. ill just have to buy the napa rotor since u406 does not seem to be made anymore.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So, am I reading that right Tim? Are they claiming to have Original DR ignitions parts for sale???
Denny Graham Sandwich, IL
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I was told all AC Delco stuff was not made in America anymore, if that matters? China, Japan and Mexico to name a few.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no Denny, you missed the note: "These items are manufactured by a variety of reputable tune up part suppliers and not necessarily by the original equipment manufacturer."
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, I sure did miss the note. So, why not just order the tune-up from JC or Chevs of the 40's or such, I'd bet a dollar to a donut that the reproduction parts all come from the same spot. I've been using the repro parts since I brought the old gal home in '05. Granted they taint the same quality as Delco was and I'd rather have the origiinal Delco Remey parts but as I said earlier, Delco probably hasn't made replacements for several decades. The original Delco coils actually fit the clamps and the terminals clips held the wire terminals much better. The point sets, caps and rotors were made, well, just better and fit better. But at least we do have someone that is making a replacement even if it's not quite up to snuff. We've got similar problems with many other old school manufacturers, such as Walker, who used to make complete exhaust systems for these old truck but now you can't even get a muffler that matches the original from them.
DG
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I believe Delco slowly moves up the years dropping things from the lists, pretty much the oldest actual Delco available now is mid-late 60's, but it's sometimes the case that some items listed for newer applications [and other makes] are actually the same part that was previously listed/sold for earlier GM vehicles, like the rotor discussed above .... but all the tuneup stuff for the 235 is available from NAPA around here, don't see why anyone would want to order something from a distant source and have the problems involved with returning a defective or incorrect part also, rotors, caps and other ignition parts don't have a makers name emblazoned on them anyway and Standard being such a major brand, even stuff in Delco boxes could be from Standard  Bill | | |
