2 members (homer52, Tronman), 113 guests, and 5 robots.
Topics128,077
Posts1,056,033
Members48,433
My truck has some homemade front mounts. Will the mount kits that most of the venders sell work here? The engine is a 350 crate engine.
http://s1189.photobucket.com/albums/z434/camsore/?action=view&current=IMAG0782.jpg
Thanks Larry
If you mean the original style factory motor mounts, they will only work if the engine block has the mounting wholes in the front of the block.
If you're refering to the tubular crossmember mount, yes it will work.
Tommy
59 apache 1/2t
261 short stepside
Larry - pic of repro factory mount installed on a 283 in a '58 - they come complete, as Tommy says, if you've got the mount holes in the block [most do] just add bolts and you're good to go
From what I understand, the holes are present on all Small Block Chevy engines, though they may not be tapped.
Bill Burmeister
That is what I was lookng for. I know my holes are tapped because the homemade mounts are bolted on there. I think these mounts I have are making the engine set to low.
Thanks Larry
from your picture it does look a bit low - American Classic has ME839 - here
Have added a few more photos, notice how close the fan is to the crossmember. I see some small holes in the crossmember, do you think they were predrilled at the factory for a V8?
Thanks Larry
http://i1189.photobucket.com/albums/z434/camsore/IMAG0804.jpg
http://i1189.photobucket.com/albums/z434/camsore/IMAG0805.jpg
the mount holes for the frame bracket are always there, from the factory it would have been riveted in, the repro brackets bolt in the same holes, see my pic above - the big hole next to the bracket is where the 235 mounts and where your home made ones are - support the engine, pull those DIY pieces, and the correct mounts should bolt right up
That should make it easy to install. I plan on using grade 8 bolts. Can I support the engine using a 2x4 laying flat pushing on the pan?
Thanks Larry
should work fine if the jack has a wide enough base to be stable - take the top nut off the frame side of the mount and jack it till you get a slight lift and it should be close to the right position
