BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,781 Posts1,039,299 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2012 Posts: 22 New Guy | New Guy Joined: Apr 2012 Posts: 22 | I have a 1951 Chevy 1/2 ton and would like to rewire the entire truck. I will have the frame stripped so everything is accessible. It seems like the store bought harness sets are expensive. Should I use wire spools or is that asking for trouble? Also is anyone aware of a good color coded wiring diagram? | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | Shop Shark Joined: Jun 2009 Posts: 2,201 | Just my opinion, By the time you add in your time and brain damage figuring it all out, and based on the price of wire, connectors, solder and tape, I think the wiring harnesses are a bargain. | | | | Joined: Oct 2006 Posts: 843 Shop Shark | Shop Shark Joined: Oct 2006 Posts: 843 | my opinion,buy a specific harness for you truck | | | | Joined: Jun 2006 Posts: 693 'Bolter | 'Bolter Joined: Jun 2006 Posts: 693 | i have to support this opinion as well - get a harness. it makes the job so much easier. | | | | Joined: Sep 2006 Posts: 3,597 'Bolter | 'Bolter Joined: Sep 2006 Posts: 3,597 | I agree with the above posters buy the harness you can still get a decent harness from some of the vendors for $150-250 and they are numbered for easy installation so you won't need the diagram. I bought mine for $150 from www.ClassicParts.com and have had zero issues. They sell them for alternators or generators. | | | | Joined: Apr 2012 Posts: 22 New Guy | New Guy Joined: Apr 2012 Posts: 22 | Thanks for the responses! It's unanimous....You have convinced me to get the harness. | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | Shop Shark Joined: Jun 2008 Posts: 1,388 | Yes, the right harness is sweet. I once had a '79 Harley, that the previous owner had rewired with all black wire. All the same size. Trouble shooting was such a nightmare, I tore it all out, and bought a harness for it. It was so much easier! | | | | Joined: Apr 2012 Posts: 22 New Guy | New Guy Joined: Apr 2012 Posts: 22 | Thanks Christopher! I would have to be a moron (don't ask my wife....) to not use a bought harness.... | | | | Joined: Oct 2011 Posts: 71 Wrench Fetcher | Wrench Fetcher Joined: Oct 2011 Posts: 71 | I redid my 51 with A kit from American Autowire.... not cheap, but worth every penny. | | | | Joined: Dec 2003 Posts: 2,952 'Bolter | 'Bolter Joined: Dec 2003 Posts: 2,952 | All the kits I looked at had more circuits than I'd ever use. I have a bare bones truck with a generator and turn signals. I wired it myself and I am no expert. I used the schematic in the shop manual and replaced one wire at a time. Good wire, good connectors and a good crimping tool plus a pull test when done. The truck wiring is very simple. And yes I used all black under the hood because the longest wire is about 3 feet and anyone can trace that. My biggest problem was doing the gauges (still in progress) because of my size and the access. | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Having color-coded wiring is very convenient. As Brad posted above, the basic wiring harness from Classic Parts is hard to beat (in quality, convenience, and cost - and in minimizing headaches for you and for others in the future). | | | | Joined: Aug 2008 Posts: 290 Shop Shark | Shop Shark Joined: Aug 2008 Posts: 290 | I too agree get a harness I have the one mentioned in my 1953 & I have a 12 circiut universal one I bought of ebay for $65 & it works great as well. | | | | Joined: Apr 2008 Posts: 133 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 133 | southern rods also for harnesses. usa made and good instructions.
daren | | |
