3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#841522 04/05/2012 10:54 PM
I need to replace the starter button on top of the starter and my replacement has an extra side post. Should I just hook the two wires on the main post and ignore the side post screw terminal completely. Thank you.
Jim-
The side post is to shoot 12V to the coil when the button is pushed, by-passing the ballast resistor. If you are 6V, ignore it.
