8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
I have 1 wheel cylinder bleeder that is 3/8 and the other 3 have "tits" sticking out that won't turn. They are internally threaded at 8/32. What is this thing and how do I bleed the brakes? Any info is appreciated. Jim
1953 Chevy 3100 3 window
1997 VW Rialta Motorhome
2011 Fusion
Jim, I had those on my truck, too. I replaced them with regular bleeder screws. I couldn't figure out how I was supposed to bleed the brakes with that setup and I figured it was easy enough to just put new ones in.
1956 Chevy 3200
If your wheel cylinders are in good shape try Speed Bleeders for replacements... Makes bleeding brakes easy when doing them alone...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Chucked that thing in a vise and vise grips and chisel wouldn't budge the screw.I drilled it out and popped the sealing part out of the hole. Chased the threads with a 5/16-10 NC. Tried screwing the normal 3/8 bleeder screw in, but it has a looks like NF thread. They have different threads in some wheel cylinders? I don't think I actually cut new threads because the tap went in easy. Jim
2011 Fusion
