1 members (carbking),
142
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | 49 one ton later model 235 engine 6 volt system mostly original wiring. I have been reading for a while tonight and didn't see anything that fits my truck without hijacking someone else. My truck was running fine and all guages working. Then one day the ammeter quit working. It wouldn't move from the middle First thing I did was pull the cover off of the regulator and clean the contacts. No change. Diagnosed probable bad generator. Removed the generator and took to a shop that specializes in starter/alternator repair. The kid working there had never seen a stomp starter but the owner/old man tested it and said it was good. I put it back in and no change in the ammeter. I charged the battery and drove it down to the shop that looked at the generator. The old guy came out with a volt meter and a jumper wire and after a couple of minutes said the regulator was bad. He jumped the wires on the regulator and got the ammeter to work. He said the wiring and ammeter itself were alright. On the drive home the ammeter flashed working a couple of times then nothing. I pulled the regulator out of my 53 6500 parts truck and put it in and polarized it and nothing. I am hopimg for some ideas before buying a new regulator if that is no 100% the problem.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Read "Hotrod Lincoln"s replies in this post. It is a long thread with good info.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
