4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#84116 10/11/2007 10:12 PM
Now that I have put a few hundred miles on my truck (57 350/ T5) I am frustrated with the transmission. Using the search function, I have visited the 5speeds and thegearbox websites, but my question remains: what are the gear ratios of the individual gears in my trans? I know first is about 4:1, fourth is 1:1, and fifth is about .78 : 1. Is there a website that might give all gear ratios based on the tailshaft tag number?
The engine has fantastic low-end torque, and the easiest shift sequence is 1-3-5. I would like to replace the transmission, but I don't wish to replace it with a different box but the same gears.
#84117 10/11/2007 11:11 PM
Riding in the Passing Lane
1972 Chevy c10 Cheyenne Super
#84118 10/12/2007 1:43 AM
http://www.inliners.org/Jack/t5_page.html
What is your final drive ratio, you may want to change to something lower than what you have vs the trans
I ran a 3:42 rear with an SBC in a half ton for a while, great gears for general use. A little light pulling a large load, so acceleration was not the greatest up a grade.
#84119 10/12/2007 12:11 PM
Just came from Mongos Garage site and the PDF that he has posted lists two hundred fifty different tag numbers for the T5. That is unbelievable that they produced them in that many different configurations. It looks like finding one with the exact gear ratio,shifter and speedo that your looking for would be next to impossable.
Was the T5 made under the GM name or Muncie or Saganaw or some other????
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#84120 10/12/2007 1:02 PM
knuckle head
knuckle head
All the T-5's from S10's or even an Astrovan have too low of a first gear for anything but a stock 216 or a truck used to pull some weight.
The Camaro V-8 T-5 has the best gear ratios,the 2.95 first is identical to the original 3 spd in old trucks.The Camaro T-5 needs no reworking of the clutch spline or release bearing sleeve,takes the common late GM 26 spline clutch readily available in 10 and 11 inch diameters.However,the shifter is back too far for older trucks.You can adapt a S10 tailhousing quite easily if you're handy at such things.There's also an external shifter relocation kit available designed for Mustang T-5's that will work on a GM version.
The V-8 Camaro T-5 88 and up Worldclass is somewhat more durable too,a torque rating of about 300 ft lbs.up to the late 80's Camaro box has a mechanical speedo drive.
#84121 10/12/2007 3:01 PM
Here is what I have saved using a ratio calculator from some years ago
Note:
there are at least two different gear ratios:
one for autos (camaro/firebird), one for astro & S-10 / s-15/ sonomas. i do not believe trumac made any more.
you can put camaro gears into an s-10/15 housing. this is known as a Hybrid T-5
wink
auto input shafts have more splines than s series. 16 vs 26 if my memory is working today.
Tire Diameter 2: 28.5 inches
Rear Gear Ratio 2: 3.43:1
MPH
RPM 1st 2nd 3rd 4th 5th 6th
1000 8 12 18 24 32 0
1500 12 18 27 36 48 0
2000 16 24 35 47 64 0
2500 20 31 44 59 80 0
3000 24 37 53 71 96 0
3500 28 43 62 83 112 0
4000 32 49 71 95 128 0
4500 36 55 80 107 144 0
5000 40 61 89 119 160 0
5500 44 67 97 131 176 0
6000 48 73 106 142 192 0
6500 52 80 115 154 208 0
7000 56 86 124 166 224 0
7500 60 92 133 178 241 0
8000 64 98 142 190 257 0
CHEVROLET T-5 Borg Warner Transmission Ratios:
1st: 2.95 2nd: 1.94 3rd: 1.34 4th: 1 5th: 0.74
Tire Diameter 1: 28.5 inches
Rear Gear Ratio 1: 3.73:1
MPH
1000 7 11 16 22 29 0
1500 11 17 24 33 44 0
2000 15 22 33 44 59 0
2500 18 28 41 55 74 0
3000 22 34 49 65 88 0
3500 26 39 57 76 103 0
4000 30 45 65 87 118 0
4500 33 51 73 98 133 0
5000 37 56 81 109 147 0
5500 41 62 90 120 162 0
6000 44 67 98 131 177 0
6500 48 73 106 142 192 0
7000 52 79 114 153 206 0
7500 55 84 122 164 221 0
8000 59 90 130 175 236 0
Rear Gear Ratio 2: 4.11:1
MPH
1000 7 10 15 20 27 0
1500 10 15 22 30 40 0
2000 13 20 30 40 54 0
2500 17 26 37 50 67 0
3000 20 31 44 59 80 0
3500 23 36 52 69 94 0
4000 27 41 59 79 107 0
4500 30 46 67 89 120 0
5000 34 51 74 99 134 0
5500 37 56 81 109 147 0
6000 40 61 89 119 161 0
6500 44 66 96 129 174 0
7000 47 71 103 139 187 0
7500 50 77 111 149 201 0
8000 54 82 118 158 214 0
Jim & Caroline
#84122 10/12/2007 4:21 PM
Thanks, guys. I knew you would come through. Mongo's Garage has the perfect table. I found my tag number, and it confirmed what I had suspected.
I have 3.36 rearend, and with conservative driving, I can get 17 mpg. I think if I can change to a 2.73 rear, and a different T5, all will be well.
