1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#840872 04/03/2012 3:36 PM
My 51 3800 has a tag screwed to the dash showing the shift pattern. Is this original to the truck? It is a former Navy vehicle and also has a plate attached to the dash stating such. Finally getting around to working on the dash and was trying to decide whether to clean the tags up and put them back on the dash, or weld in the holes and finish the truck without tags. Thanks in advance.
51 1 ton Panel
Betty, she's a handful
For the transmission? 4 wheel drive vehicles have plates like that for the transfer case and any PTO instructions.
Not uncommon for military vehicles to have such plaques. It's your truck, but I would put the tags back on after you finish the dash. Just too much nostalgia and history to let go.
Drew
I think they look cool and obviously authentic.
Could you please post a picture of the Navy Dept tag so I can get the data off it for my records of Navy vehicles that I've been researching for over a dozen years. And please leave the tags on the truck, it is it's history. Thanks, Mike
59 GMC rare fleet option stepside pickup
57 Chevy sedan delivery
57 Ma Bell windowed panel (gone)
57 Ma Bell 150 sedan (gone)
57 Burb with p/s, Apache Res. school bus (gone)
56 Navy 3100 pickup (pieces)
56 windowed sedan delivery (US Dept. of Ag.) (gone)
55 Navy 150 sedan (gone) and many others now gone
Founding father Desert Classics 55-57 Chevy club now gone
I have this one mounted on my truck I found it on a '52 I bought for parts. I didn't drill my dash but cut the screws flush and glued it on with acrylic caulk so I could remove it (I centered it between the gauge clusters).
Original location:
http://good-times.webshots.com/photo/2888466550102454676YjhoMM
Close-up:
http://good-times.webshots.com/photo/2515462660102454676AkgUKk
Brad, that is the same I have mounted on my dash, sm420 shift pattern I believe. It was screwed on with clutch head screws. It is in good a shape as yours, needs a good cleaning. Is there a magic formula to clean these with? Thanks
Mike, I will post a pic of the Navy tag as soon I can find it, should be in the same box as the dash parts I removed 2 years ago.(Yeah I am right on schedule 4+ years and counting) The Navy tag is not in great shape has some pitting on it, will have to figure out how to clean it up. Is it possible to trace the history of the vehicle through these tags? Thanks
51 1 ton Panel
I used an SOS pad (gently) with warm water it cleaned up really nice.
Crusing in the Passing Lane
The're on there because any Tom, Richard, or Harry might drive it.
