1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | With the prospect of driving my daughter in several parades this summer, I decided that this was the year to add a PCV system to the 235 in the '51. I'm usually one to figure things like this out on my own, and this case was no different. I did some research and found a couple of different procedures to add the PCV, but I wasn't really happy with some aspects. I also had some good advice from someone whose opinion I respect. I wanted to find something that didn't require much investment, or any special parts or tools. This is what I came up with. I started out at my FLAPS. I picked up a PCV valve. I didn't pay attention to which one. As far as I can discern, there isn't much difference in them except the mounting hole size or hose size. I also picked up an oil filler cap for an early '70's F*** truck (Murray p/n 8071). This cap is non-vented, contains gauze filter material inside and has a mounting hole in the top for the PCV valve. I also picked up a length of hose and a fitting to connect to the vacuum port on the intake manifold. I won't bore you with installation instructions for that. I think you all can figure that out. For the fresh air intake, I decided to use the road draft tube. Well, part of the road draft tube, anyway. One of my parts engines had the tube removed from the breather. I used this one, because I was concerned that highway driving would leave the draft tube and PCV competing, and the engine loosing all ventilation. After a couple of weeks of soaking in gasoline to loosen and remove all of the built up sludge, I painted the tube. Next, I installed some gauze type filter media that I found at the FLAPS (Micro-Gard p/n 42998BP). I wanted to do this because, even though the tube was baffled, I didn't feel the baffeling would provide adequate filtration to the incoming air. This gauze filter is the same type that was used in PCV filters on older carbureted vehicles. I think that the end result will give a good air flow through the engine without too many modifications. I'm open to comments, but please be kind... http://s247.photobucket.com/albums/gg136/8trackdude/PCV%20Valve/
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I've been thinking of adding a PCV mainly to contain the fumes coming out of the rocker cover after the engine is shut off(due to complaints the garage "stinks" - personally I like that old car smell). Your set-up looks very clear cut. Do you get smoke/fumes out of the crankcase breather after you shut off the engine? Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think you have it wrong way round Tim, you should be sucking the fumes out of the road draft and allowing fresh air into the oil fill cap - that's the way the factory does it and why it's called "positive crankcase ventilation" .... when moving, the road draft tube draws air out, so you'll only have air in when sitting at an idle, and there's not really much in the way of fumes in the top cover
same for you Dave, the PCV won't have any effect on what you smell after the engine is shut off, and any vapor you see from the rocker cover will be primarily water vapor - more likely the garage smells like the exhaust fumes and leaking fluids evaporating from the outside of the hot engine
Bill | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Im with Red. I'm running a PCV valve in the Road draft tube where you have the fresh air comming in. Use a breather cap or filtered air from air cleaner. That's the way factory PCV (i.e. 261) plumbed it.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Positive airflow works either way- - - -the system doesn't really care which way the air gets into the engine. Internally, a PCV valve consists of a spring-loaded tapered plug that takes small gulps of air from the crankcase (or valve cover) as the manifold vacuum pulsates slightly between intake strokes. Otherwise, there would just be a massive vacuum leak and the engine wouldn't idle worth a flip. Getting clean, filtered air into the engine is the trick, either by adding a filter at the inlet, or just pulling air from the "clean" side of the main air cleaner. That's how we did thousands of conversions to PCV in California back in the 1970's when the California Air Resources Board ("CARB"- - - -how's that for irony?) decreed that all engines on California roads had to be retrofitted for sealed crankcase ventilation systems. Jerry
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I pondered this for quite a while. I know the OEM PCV system vented from the draft tube. I also know that others have retrofitted their engine with the PCV valve in the draft tube location. But, on the other hand, more "modern" engines like the 230/250/292 put both the PCV valve and the fresh air intake in the valve cover. Like Jerry said, it doesn't matter where the things are located, as long as there is a vacuum side and a fresh air side.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am pretty sure there was an early GMC setup that had the air intake at the draft tube location. I mounted my PCV there and I use a vented oil cap. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I started with mine that way. I was unhappy with how my vacuum line plumbing turned out. It wasn't nearly as clean as yours. Plus, I have a tendancy to think, rethink and rethink things again.
