2 members (porsche, MickeyP), 124 guests, and 1 robot.
Topics128,051
Posts1,055,767
#839834 03/30/2012 4:10 AM
I broke the bottom part of the frame that holds the glass from the vent window assembly. There appears to be a pin that the window pivoted on that broke. The top connection/pivot point is still connected.
Is there a way to fix this or am I looking for a replacement?
1964 K10 Fleetside Pickup Truck
I am not an expert but I looked at the vent window on my '65 C20 and the LMC catalog and it does seem like the pin is part of the vent window assembly. LMC does sell a repair kit which looks like it might be the pin. You could call them and ask. Otherwise, you could look for an original used assembly. It would be original and probably alot cheaper than the aftermarket one. Good luck.
1965 Chevy C20 Stepside
