| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Rebuilding a 53 235 Powerglide engine. Bored .020 over, Patrick 254 cam, Offy 1034 manifold, 2 identical 483s W-1 carbs, Fenton headers. I'm one county over from you, so same elevation.
Question: what would be the best needles to use in the W-1s, for best streetability? | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | We suggest ALWAYS starting with the stock configuration. This way you have a repeatable "baseline".
Do you have any heat to the intake?
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | I'm planning on running water heat to the manifold. The engine is dissassembled in my shop right now, it will be heading to the machine shop soon. Getting the parts together and planning the build.
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Sounds like a fun project.
Incidentally, the cheapest horsepower you can buy would be to replace the powerglide with a manual transmission.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Ah, you see, the engine is destined for my sons 1945 truck, with 4 speed manual transmission. I only call it a Powerglide to indicate it is a pressure oiler. In 1953 only the Powerglide motors had the new oiling system.
I'll be using mechanical lifters as well. | | |
