2 members (TUTS 59, Maybellene), 157 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#840222 03/31/2012 9:57 PM
volume and vacume test was good at carb. i still must test vacume at manifold wipper outlet if gas tank is1/2 full it runs much better than tank full ,dosnt it aliminate timing and valve adjustment.then i will check cleaning carb. i will keep you posted i do not have ez acsess to inter net.thanks
3B Offline
Hy oldchevyguy, when it acts up remove the fuel tank cap and see if you hear a rush of air into the tank. If you do, the vent in the cap has plugged, and it's time to replace the fuel tank cap, hope that helps.
Trash in the main metering jet in your carb can cause the symptoms you describe.
I went one day to buy a old Harley Davidson, shift on the side of the tank old. The bike looked great, but it would not stay running unless you had it almost on full choke. I decided not to buy it thinking there was major trouble somewhere. Well, as the luck goes I ran into the man that owned it later on. He told me that it had a bad vacuum leak at the carb. Did I buy it then? Nope, he already sold it. Boo-Hoo. Check REAL good for a vacuum leak. Somewhere. Good luck.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
