4 members (J Lucas, klhansen, kurbside bolter, JoergK.), 161 guests, and 1 robot.
Topics128,266
Posts1,058,369
Members48,485
#840162 03/31/2012 4:40 PM
1950 chevy 3100.
Rebuilt carb and distributor, vac advance.
Fill gas tank, truck runs great through about 2-3 gallons then behaves as though it was out of gas.
Add 1-2 gallons and it starts up immediately.
Vapor lock? Fuel pump?
Thanks for your help.
Kurt
Have the gas tank, pick up and lines been cleaned?
Give me ambiguity
or give me something else
CASO #840189 03/31/2012 6:36 PM
Just purchased truck last month.
Have not checked fuel lines.
Please define pick up.
thanks.
Think he means the fuel pick-up in the bottom of the tank. Crud and sediment collect there, and can clog the fuel flow intermittently.
This sounds like a classic case of a blocked breather in the gas cap. Does the tank "ping" when you take the cap off just after it's bogged down? Will it run fine once you remove the cap?
May need to check your fuel flow at the carb.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
