| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 17 New Guy | | New Guy Joined: May 2010 Posts: 17 | 50 1/2 ton. I'm in need of the connector that attaches the DASH hand throttle cable to the carb linkage. Don't know the actual name. Anyone know where can I get one? Thanks,
Lampo 50 1/2 ton project
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have 46 but I think it is the same. It's a cylinder drilled through and threaded for a set screw. The diameter is drilled though for the cable. My package says "Cable Stop" I got them at the local auto parts store. They also had the linkage to carb clips that hold the linkage to the carn. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Lampo, you are looking for a "cable stop", they are available in the "help" section of most F.L.A.P.S.. Does your carb already have the double function cable holding bracket, one side for the choke cable and the other for the throttle cable? If not you'll need one of those as well, post an ad in the parts wanted forum if you need one of those. The throttle cable end goes through the hole in the throttle rod that attaches the the carb (where a cotter pin would go) then you put the "cable stop" on the end of the cable, leaving a bit of clearance between the carb arm and the "cable stop", hope that helps. | | | | | Joined: May 2010 Posts: 17 New Guy | | New Guy Joined: May 2010 Posts: 17 | Thanks, I'll check it out. Lampo
| | | | | Joined: May 2010 Posts: 17 New Guy | | New Guy Joined: May 2010 Posts: 17 | Gotta love this forum. Quick trip to AutoZone. THe throttle cable stop. Headed to the garage to install. IT HAS BEEN 1 HOUR SINCE FIRST POST AND IT IT DONE. THanks to all. Lampo
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | throttle hookup picture here Lampo Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That linkage clip Bill, we went thru this a month or so ago but I couldn't find a source for them. I think it was Gus that first posted a picture of a clip on his throttle linkage. At the time I thought it was a good idea to add that and still do. I’ve never felt quite sure about the wire only to secure the link although I’ve never heard of anyone having a malfunction. When I saw the clip I went on a search to all of the FLAPS in the area. I got several HELP packs and a handful of loose ones but none of the clips had a wide enough opening for that flaired out opening in the throttle lever.
I'm pretty sure originally all that Chevrolet used was the throttle wire thru the link with the brass stop on the end of the wire. In other words, originally they didn't have a "clip" like those used on the later throttle linkages or the one shown in your link. If that's not true I'd really like to have some documentation for my records. Also I’d really like to know if anyone has found those ¼” clips with the wide opening and who has them. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I haven't had to look for those linkage clips Denny, I've always saved all those little bits that usually get lost over the years, and for the brass stops, some carbs have them 'built in' to connect the choke cable end and I save them off scrap carbs .... can't say what was original on the AD's, and the TF series hand throttle hooks up differently
Bill | | | | | Joined: May 2010 Posts: 17 New Guy | | New Guy Joined: May 2010 Posts: 17 | GREAT PICTURE thanks, now mine looks just like it. Anyway to adjust the tension on the pull knob? If I pull it out, it just goes back to idle from the spring on the throttle linkage. Thanks again. Lampo
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Hey, I think that's a pic of my motor! Autograph signing after work! Lampo, I assume you have a throttle wire, not a cable? Maybe it is too lubricated in the housing? Maybe your return spring is too firm? Here's another couple pics of the hookup. Once you click on it, hit the "next" button to see a couple more pics: http://rides.webshots.com/photo/1130825413050768402MNkigr
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I bought some clips at O'relies auto parts. Used to be shucks and Kragens. They had a package and it had one that fit the throtle. | | | | | Joined: May 2010 Posts: 17 New Guy | | New Guy Joined: May 2010 Posts: 17 | Thanks for a peek at the pictures. I do like the clip on the linkage.
I have a wire like yours, only it's new and works, probably, to well.
Also the spring does seem a bit strong. It is pretty substancual!
| | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | What is the deal with a Throttle cable - it's purpose? I have the knob in the cab with the cable going to the carb with all the linkage there - but its not really hooked up. You guys are probably chuckling and maybe I it's obvious, but I don't understand it - can't you just step on the accelerator - why an additional cable? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Do a site search, that's been discussed a number of times. There are a number of opinions on the subject.
| | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | Yeah, sorry, I should've done that. Got it, my bad - note to self: Search fist, ask later. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | RE: the linkage clip in the pic that Bill (red58) posted ...I was stumbling around the '29-'54 MPC and found these pics and descriptions. Group 3.425, Part #3700188, "CLIP, carb. to accel. lever rod attach." for '53-'54 passenger car. Also part #3703528, "CLIP, carb. to accel.lever rod attach, accel. front rod swivel" '54 COMM. w/A.T. (automatic transmission). Didn't check later dated MPCs
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
