7 members (KEVINSKI, Otto Skorzeny, Tronman, Charles in CA, Goach2, 66flea, 1 invisible),
233
Mod | | | Forums66 Topics128,257 Posts1,058,015 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | What would the thickness of the door window glass be on a 47-50? | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Someone will probably prove me wrong but I believe automotive flat glass is 1/4".
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Wing vents are 5/16" I believe this is 2- 5/32" thick single pane with a laminate tape of about .001"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The door glass I removed from my 50 is just under 1/4. It is two sheets of laminate and the two sheets look to be different thicknesses ...pic... I measured it with a mic also and its .237 I had an auto glass shop cut my new glass. | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | | | |
