2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I broke the bottom part of the frame that holds the glass from the vent window assembly. There appears to be a pin that the window pivoted on that broke. The top connection/pivot point is still connected.
Is there a way to fix this or am I looking for a replacement?
1964 K10 Fleetside Pickup Truck | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I am not an expert but I looked at the vent window on my '65 C20 and the LMC catalog and it does seem like the pin is part of the vent window assembly. LMC does sell a repair kit which looks like it might be the pin. You could call them and ask. Otherwise, you could look for an original used assembly. It would be original and probably alot cheaper than the aftermarket one. Good luck.
1965 Chevy C20 Stepside
