2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#839683 03/29/2012 7:13 PM
1 Offline
Im going to buy a used engine fan for my 350 this weekend. I was wondering if all the bolt patterns are the same for every year or at some point did they change it a little. My engine is a 1987 carburated. When i bought it it didn't come with the fan and my 1964 283 fan bolt patterns didn't match up.
Riding in the Passing Lane
There are 2 different patterns.
1972 Chevy c10 Cheyenne Super
George is right, the later ones are usually the bigger bolt pattern. The early water pumps can be either way. I've seen most of the long water pumps with the big bolt pattern.
don stocker #839765 03/30/2012 12:50 AM
1 Offline
Do you know what year they switched over to the bigger bolt pattern? i imagine sometime around when they switched over to fuel injection. I just sort of want an idea of what to look for when i go to a junk yard to pull one.
look for years around the year of your engine, or just measure the hole spacing on your water pump and find the same, that's what counts, likely any fan from any 350 will fit
Flxible #839888 03/30/2012 1:07 PM
'73 and up should work
don stocker #839949 03/30/2012 7:00 PM
1 Offline
would i be able to buy a clutch type fan and just take the clutch off?
The clutch type fan will only work with the fan clutch. The bolt pattern does not fit either size water pump.
don stocker #840114 03/31/2012 1:30 PM
If you look at vendor sites you can buy a regular fan at a reasonable price.
