2 members (Opelika Tom, Otto Skorzeny), 86 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
#839098 03/27/2012 4:11 PM
Camp Commandant
Camp Commandant
On my GMC there are holes in the frame (not the rusty kind but drilled holes) that could be factory or could be from a previous owners use of some kind but I don't need them all. Is there anything wrong with welding them up?
Here is picture that shows a little bit of what I am talking about
http://rides.webshots.com/photo/2917367460083734483ZlwjgW
~ Billy
1959 GMC 860 | Pictures
I'd be very reluctant to do that much welding in a small area. If you decide to do it, weld a few holes, let the frame cool completely, and do a few more. There's a distinct possibility of creating brittle spots and/or warping things. Definitelt DO NOT do any welding on the frame flanges without following up with some sort of stress-relieving procedure afterwards.
I'd leave all the holes you can tell are factory.
In my mind you're supposed to see holes in a big truck frame, they were there for other options or configurations, it's expected. What might look wrong is a completely slick frame with no extra holes. And you'll find some of them handy for other stuff as time goes on.
Probably leave any non factory holes too unless they just look wrong. Any holes in the frame you don't like I probably wouldn't weld them though. Small ones can be tapped and screw a bolt in, trim off the ends and peen and grind it flush. Larger ones you could use some JB weld sort of stuff if you really wanted to (probably not ideal but safer than welding a lot). Also consider dressing any buggered holes clean with a slight chamfer so they look good/factory.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #839235 03/28/2012 2:30 AM
Camp Commandant
Camp Commandant
I was pretty sure that this was the advice I was going to get. I just keep looking at all those holes with out the tank brackets etc mounted. I'm sure they won't be as noticable once everything is painted up and back together.
Thanks for keeping me in line.
~ Billy
Crusing in the Passing Lane
Billy, Nice to see your truck moving along, is it going to be at W. Springfield?
Camp Commandant
Camp Commandant
Hi Ed. I haven't made any progress the truck in a while but hope to start putting some more time in on it now that most of the home flood repair project is done. I wish it was ready for Springfield but its a long way off from the truck show circuit!
~ Billy
