5 members (Hotrod Lincoln, baldeagle, Otto Skorzeny, TooMany2count, Shardean), 125 guests, and 3 robots.
Topics128,024
Posts1,055,392
Members48,422
#83932 10/09/2007 7:25 AM
Apprentice
Apprentice
This is not just for Carb King But anyone with Rochester carb. knowlage.A buddy of mine just gave me an old carb he had sitting on a shelf to replace mine (Rochester B seires on a 57 235 leaker)The numbers on the brass trianglar tag are 7028028,there are numbers on the base 7022945.Any help would be great!Thanks in advance AL
"What Dirty Scoundrel Stole The Cork From My Lunch" W.C. Fields
#83933 10/09/2007 2:05 PM
Carburetion specialist
You might take a second look at that tag number.
Jon.
The Carburetor Shop
#83934 10/09/2007 6:14 PM
Apprentice
Apprentice
Yep your right!It looks like 7026028 maybe.Thanks Al
#83935 10/09/2007 11:31 PM
The Carburetor Shop
#83936 10/10/2007 2:00 AM
Apprentice
Apprentice
Thanks Carb King,yet again helping!I guess my next question would be,can I run this carb until I find a suitable replacement?Shes not even close to being on the road just trying to get her running again without catching on fire.Any mods you can think of to make it work?Thanks again Al
#83937 10/10/2007 3:43 AM
Personally, if the vehicle is not yet road-worthy, I would continue to search for a suitable carb. smile
If the vehicle was completely finished, and this was the 3rd of July, and you really wanted to put the vehicle in the 4th of July parade, and a carburetor was all you needed.........I would rent a trailer! wink
Others' opinions may differ.
Jon.
The Carburetor Shop
#83938 10/10/2007 4:36 AM
Apprentice
Apprentice
Thanks for the reply,but right now I,m trying to figure out if this motor is worth bothering with.Not as anything other than this Thanks Al
#83939 10/12/2007 4:39 PM
Apprentice
Apprentice
Anyone else have any ideas for a no cash flow bolter?Thanks Al
#83940 10/12/2007 8:26 PM
Al, if you are just going to start the engine, and run for a few minutes at idle, go ahead.
But I would not suggest driving the vehicle with the carburetor.
Jon.
The Carburetor Shop
#83941 10/12/2007 9:31 PM
Riding in the Passing Lane
Take the top off of it & see if it,s clean inside & everything working right. You can get a kit for about $15 & freshen it up. It should run good enough to check it out & move it around.
1972 Chevy c10 Cheyenne Super
#83942 10/16/2007 4:30 PM
Apprentice
Apprentice
Wrenchbender,I went threw my Rochester from top to bottom and just cant get it to seal.I saw all the threads about this carb but its really not worth it because its not original and will be replaced with a Carter 2101s when I can find one.Thanks again all Al
