7 members (Jon G, Wayne67vert, KEVINSKI, 50Chevy3100, 1955 1 Series, sron48, 1 invisible), 46 guests, and 8 robots.
Topics128,012
Posts1,055,311
Members48,419
Hi,
a new problem has occured: Today after I had done the wiring for the park lights/turn signals I wanted to start my truck to see if it all works correctly.
When I turn the key to the first position ("on") it cranks already. Is it a problem with the switch or with the wiring?
The next thing is the wiring of the tacho. I have a gauge cluster with factory tacho. I got a new harness for that thing as the old one had been cut off and ripped out. So I don't know where it connects to the main harness. My wiring diagrams doesn't show any tacho. It has to plugs and one furcated cable lug. Can anyone provide pics or has a wiring diagramm which shows that?
Greetings
Joern
'65 C-20 Fleetside 283 4-speed-MT
can't say anything about your tach setup, but for the start situation, obviously you wired something very wrong - need to work with the wiring diagram carefully, you probably have some wires to the wrong terminals on the switch
I can't imagine since it all worked fine until yesterday. I will disconnect the wires from the ignition switch and check how it works.
Doesn't anyone have a pic from the fuse panel where the tach is connected? Or any other information?
