4 members (MickeyP, KEVINSKI, jay d, Otto Skorzeny), 153 guests, and 2 robots.
Topics128,034
Posts1,055,552
#838985 03/27/2012 4:05 AM
I have a 64 k10. My transfer case has a slight leak from the gasket where the driveline and transfer case meet. Does anyone have any experience removing the driveline from the transfer case? Im trying to determine the difficulty of doing this. My truck drives great and i don't want to risk messing things up. I can live with the slight leak vs causing some other problems by removing the driveline. Any thoughts or direction is appreciated. John
1964 K10 Fleetside Pickup Truck
The biggest obstacle will be removing and reinstalling the transfer case. Its heavy so make sure you have some help or better yet find a transmission jack to use. Otherwise take your time, get a shop manual and replace gaskets and seals.
Sounds like you could drain the oil, remove the driveshaft and yoke and replace the seal in place. A couple hour job at the most and no heavy lifting.
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #839240 03/28/2012 2:40 AM
Thanks guys. Is it difficult to remove the driveshaft?
no
---All pictures---
