3 members (ShopRag, dt235sd, 1 invisible),
359
Mod | | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, I have a 46 Chevy Truck with a 235 engine from a 58 or 59 Chevy, numbers 3836846 GM 14. When I bought the truck they converted it to a newer starter that does not require the foot starter or a button to be pressed it just turns on. Its a 3 speed transmission and I want to get it back to the original foot starter. What are the parts I will need to accomplish this? Does it make a difference what engine you have a 216 or 235 will it fit both? Picture of Part I think I need
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Yes,
You will need that part, and you will also need the correct starter. I'm assuming you still have the original bell housing? The starter and the flywheel must match. The 6 volt and 12 volt starters take different flywheels.
Kurt | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Does the truck have the original ignition switch? Did they add a push button to engage the starter? You'll want to look at an original wiring diagram to see what has been changed on your wiring harness. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Yes,
Kurt Yes, It looks like the original bell housing, it has to holes on each side to screw in the foot starter linkage. I have a 6 volt system so I will need to check the flywheel and starter, or do I need to just replace the part that goes on top of the starter?
| | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Does the truck have the original ignition switch? Did they add a push button to engage the starter? You'll want to look at an original wiring diagram to see what has been changed on your wiring harness. No it looks like they changed the ignition switch because the key looks weird and small and does not require any button to be pushed to engage the starter. You just have to turn the key and give it gas. Where can I get a diagram of the original wireing?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | This should be pretty close. Wiring diagram
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | This is my current starter Starter Picture
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is a 1949-54 Passenger car starter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Do I need to replace the whole thing or just the top part with the fot starter?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Some of the individual starter parts are the same, but basically you need a whole 1938-48 pass or 1938-54 truck starter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here are a couple on eBay First Second
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Does the bell housing need to be dropped to install the foot starter linkage, or can it be installed left in place?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mauricioaglr, you should be able to install the linkage with the bellhousing in the truck, it will help if you have contorsionist training | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | That is funny, I would have to lose weight first and I aint got time for that  .
