6 members (78buckshot, Gdads51, KEVINSKI, dt235sd, Peggy M, 1 invisible), 178 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
#838792 03/26/2012 5:02 PM
I'm trying to take my mind off of my upcoming surgery and
Move. So bear with me.
My 261 is just about ready to fire up, I am limited in my ability to install the engine at this point, and am hoping that someone has a suggestion on how t start it without having it in the truck.
I was going to assemble one of the wood engine rolling around the shop stands in the tech section. Has anyone fired up an engine on one of these?
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
I've run engines on a couple of old tires sitting on the shop floor at times, and strapped down to all sorts of shipping pallets. I'd suggest just getting a good-condition pallet, make some 2X4 shims to level the oil pan, and use a couple of nylon ratchet straps to tension it side-to-side. Put a garden hose into the water pump inlet, duct tape it into place, and provide some sort of drain hose from the thermostat housing (Remove the stat!). You don't even have to run the water pump- - - -just get a steady flow of water going and fire it up! You'll need a battery and a gasoline supply, obviously, plus a way to turn the ignition on and off. A simple toggle switch can work for that. Have fun!
