7 members (2-Ton, Millenimech, 3800GUY, mick53, Hanks custodian, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,386
Members48,469
Hi Guys,
Does anyone know where i can get a drawing of the assembly sequence for a brake master cylinder? i have a repair kit here but not too sure as to how it all goes together. Any help would be greatly received.
regards
tim
Riding in the Passing Lane
I dont have a photo handy but I can describe it. The flat rubber washer goes in the rear plug. The cupped shape check valve goes in the spring & seats on the flat rubber. The loose rubber cup goes in next open end faceing the metal part on the spring. The piston goes in next with the rubber cup in front. Use some silicne grease or brake fluid to lube it so it wont tear. Put the push rod & thick flat washer in next & the snap ring. Put the boot over the cyl.
There are 2 holes from the reservoir into the cyl. Make sure they are not plugged up. the rear one is very small.
1972 Chevy c10 Cheyenne Super
Many thanks i will give it a go.... I am sure i came across a drawing of the assembly one day on the web, buti'm darned if i can remember where i found it frown
Kind Regards
Tim
Here is the diagram for you. master cylinder exploded view
1951 1 Ton Completed
Truckernix, you are a star, that's the diagram i'm after, many many thanks.
Kind regards
Tim
