| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I am in the process of installing new wheel cylinders on my '57 3/4 ton GMC as the fronts were crap and I suspect one of the rears to be leaking. I have fluid in one of the rear brake drums.I dont know if its from the wheel cylinder or if the seal is leaking. My question is about the seal replacement on the rear hub. It's a Spicer 60. I have the maintenance manual but need some clarification. If I understand correctly, all I need to do to get to the seal is unbolt the outer axle flange and pull the axle. No clips or anything in the pumpkin holding the axle. Then take the hub off and the seal will be on the inner opening. Is this correct? Any comments or direction is appreciated.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jmoore, I have never taken apart a Spicer 60, but that is basically how it works on all the full floating hubs I've worked on. The seal p/n is National 455860, hope that helps. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
1957 GMC 150
