2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I am rebuilding the steering, replacing the entire tie rod and ends with 1" rod. I have all of the old balls out, even the ones for the drag link. The existing drag link is so rusted I could not get the replaceable ends out so the rod itself is shot. I have seen numerous posts on making a new adjustable link, some of which involve a welding the hole shut, dilling and reaming it to fit a new tappered tie rod ned. Where would I go to get this hole reamed to the proper degree I need or does anyone have part numbers to use for replacement ends that would be less work. Maybe I need to just replace the entire drag link with a new or rebuild a one and stay with the old ball and socket. Looking for suggestions. Thanks
If you never tell a lie, you never need to remember what you said.
