3 members (panic, baldeagle, 68ironhead), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#837811 03/23/2012 2:13 AM
I AM PUTTING THE ENGINE BACK IN MY 53 CHEVY P.U. I CANT REMEMBER HOW THE FRONT MOTOR MOUNT IS ASSEMBLED. IT SEEMS SIMPLE ENOUGH, BUT I HAVE A 52 I'M LOOKING AT AND IT HAS TWO WASHERS BETWEEN THE MOUNT AND FRAME, I DONT RECALL THAT ON THE 53 ,BUT THEN AGAIN I TOOK IT APART TEN YEARS AGO.AND THE TWO MOUNTING BOLTS GO UP FROM THE BOTTOM SO THE NUTS ARE ON THE TOP AND BOLT HEADS ARE ON THE BOTTOM .IS THIS THE CORRECT WAY TO REASSEMBLE OR DID THINGS CHANGE BETWEEN 52 AND53 ALSO IS THE SEAT FRAME PAINTED THE SAME AS THE STEARING COLUMN COLOR? THANK YOU BABE
babe #837855 03/23/2012 4:18 AM
If its a 235 check out this thread
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=819953&page=1
Quote from above thread
Not sure what you’re asking Lonnie, but here are a few pictures
of how the front mount should go together:
http://www.pbase.com/dennygraham/image/128165791/large
http://www.pbase.com/dennygraham/image/128165811/large
http://www.pbase.com/dennygraham/image/136995331/large
Denny G
1947-1953 Steering Wheel, Column and Shifter Color were painted alike, Not the same color as the seat frame
Here is one guys recommendations on paint color
...click...
Color is a hot topic here.
