| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Picking up a 55.1 parts truck saturday. Current owner has unbolted cab from chassis. I need to bolt it back down for transport. Does anyone know what size bolt is required. I was hoping someone would have one easily available to measure. Thanks a million. I'll post some pics once I get 'er home. | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | On my truck the front of the cab is bolted on with two 1/2 inch-13 t.p.i. by 3 inch hex head bolts (one each side). Length does not include head. The bolt goes from inside the cab down through the frame, and ends with a large composite washer, 1-3/4 inch square washer, lock washer and nut.
The rear of the cab is bolted on with two 3/8-16 t.p.i. by 1 inch hex head bolts each side (total of four). This goes up from the bottom. Inside the cab is a threaded plate. I don't know if the plate is loose or welded (rusted ) on so might be smart to take washers and nuts. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Peter, Thanks a million. I figure I'll be ok if I can at least get the front bolts in. | | |
