5 members (Hotrod Lincoln, baldeagle, Otto Skorzeny, TooMany2count, Shardean), 125 guests, and 3 robots.
Topics128,024
Posts1,055,392
Members48,422
#837574 03/22/2012 5:52 AM
Picked up a set of steel bed strips for a 1950 Chevy half ton at a recent swap meet. Gave $20 for 'em. Will they fit a 1951 Chevy half ton? That's where I need to use them.
Thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
The strips should fit any bed from 1947 to 1953 according to the catalogs.
Drew
Thanks Drew. I didn't know if the holes would align or not. I may shoot an email to Mar-K as well just to confirm.
Chuck
1941 Chevy coupe
They will fit but you might have one to many, in mid 51 they went from 9 boards to 8.
Thanks for the info Buckstruck. I figured there was a difference.
Chuck
1941 Chevy coupe
Will I have to change out the cross members since the bed in the '51 will only have 8 boards vs the 9 boards the '50 had?
Chuck
1941 Chevy coupe
If your getting new boards you need to determine if your box used 8 or 9 pieces. Look at the rear cross member by the tailgate if it has 9 holes in it you need 8 boards if it has 10 holes then you need 9 boards.
