| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Anyone have any tips (Like get a bigger hammer) for loosening up a stuck rim? I got a new set of rims and tires for my 3600 but who knows how long sinse the originals have been removed, and the front passenger side refuses to come off. I let most of the air out of it before i broke out the hammer because it is a split rim. I tried pounding all around the studs and beat all around the edge of the rim from behind with no luck, not even a budge. Anyone have any suggestions?
Thanks, Darren. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You could try this ,loosen the lug nuts,take the truck off the jack,than shake the truck side to side.In the old days when I worked after school at the station if they got one like that they would loosen the nuts than take it out for a ride around the block that would do it.
Try spraying some liquid Wrench on it to,if all else fails put some heat on the center of the hub.
Pete | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Thanks Pete, I'll give it a try.
Darren. | | |
