| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83681 10/02/2007 3:05 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I am putting a v8 in the truck, which formerly had a 6 cyl. The pedal linkage for the carburator was an arm attached to the linkage thru the firewall that faced down, and the motion was a push. The v8 needs the arm to extend upward with a pulling motion. I suspect that the stock v8 linkage for this model truck is what I am looking for. Where can I get the part ? Thanks in advance. | | |
#83683 10/02/2007 6:28 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Thanks. The '62 has the lever down for the 6cyl., and I just assumed it would be up for the v8. The lever is hooked onto the pedal linkage thru the firewall that has a flat ground on it for the lever, so I can't move the lever around without drilling it out and then welding it up so I can grind a new flat on the lever. I could do that as a last resort, but I just wanted to same myself some grief and also preserve the origninality. | | |
