7 members (Gdads51, 55shaker, 1954gmc9314, carbking, J Lucas, dt235sd, 2-Ton),
52
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,274 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | I just bought a 48 p/u with a replaced motor.can anyone ident it for me thanks doug. casting # behind starter is 3788387 stamped # beside dizzy is 283185
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Are there no letters with the numbers from the "dizzy"? | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | 54john3100 thanks for the comeback. no there are no letter,s.I believe it,s a 235, but on another forum I came across a listing that had the twolast casting # revesed and that was a 292 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48, I couldn't find that exact casting number at Inliners International, but I did find 3738307 which is a 58-62 235, also 378307 which is a 60-62 235, please verify the casting number again, they can be a little tricky to read sometimes. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanks 3B it is difficult to see. the 5th # from the left is in doubt. will recheck,but it,s snowing and cold in abbotsford this morning. Doug | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanks 3B it is difficult to see. the 5th # from the left is in doubt. will recheck,but it,s snowing and cold in abbotsford this morning. Doug | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | didnt mean to double post sorry | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Where did you find your truck? | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | 54john I picked it up in Aldergrove.according to the serial # it came out of the factory as a cab and chassis 3/4 ton Doug | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | 3B thanks for the info. I removed the starter and cleaned the area and low and behold--the # is 3738307. the stamped # is 283185 and the cylinder head # is 3836848. would this translate to a 58-62 235 with a older head ? thank,s Doug | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48, I'm glad I was able to help. | | |
