4 members (50Chevy3100, Otto Skorzeny, carbking, 1 invisible), 74 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#836286 03/18/2012 1:26 PM
Hello,
Looking for your help identifying the crossmember in the attached picture highlighted with the red arrow. It sits about 1" behind the battery tray, is 3" wide, is attached to the frame by 4 bolts on each side, has the number "20" stamped in the middle enclosed by a circle, sits about 4 inches behind where the tranny would end. Truck is 1950 3100, I have no history on it. There are two pictures.
Thanks.
Frame/crossmember picture
Newbie
1950 Chevy 3100
It looks like it's from the factory from an automatic transmission.
Bruce
My Trucks
Stuff I Collect
That is your transmission rear support cross member.
There would be a mount bolted to it using the 4 bolt holes in the center. The mount would support the stock tranny at the ball collar
http://www.classicparts.com/1947-54-Rear-Transmission-Mount/productinfo/79-204/
V
V Offline
Yeah!
