1 members (Southerntruck),
98
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83611 10/01/2007 5:47 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I think there has been some discussion on this before. I could not find it with a search.
Can a 216 head be put on a 235? Is there anything wrong with that?
I think that I have found one.
Also, a 4 speed transmission is mated to it. I have a 4 speed transmission but this one is smaller than the one I have. And it has a lever that comes up shaft from the transmission.
Any information is appreciated.
Dennis -there is nothing stronger than the heart of a volunteer-
#83612 10/01/2007 8:33 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 216 head will only fit on a 1941-49 235. The four speed with the reverse lock-out is a non syncro trans used up to 1947,
See the USA in your vintage Chevrolet! My Blog | | |
#83613 10/01/2007 8:54 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Are these 235 engines any good? Do they have the babbit bearings on the rod ends? Are they splash oilers?
#83614 10/02/2007 2:07 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, Yes and Yes. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#83615 10/02/2007 2:27 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | A 235 has babbit bearings and is splash oiled???? I did not know that. What year 235 you talking about? | | |
#83616 10/02/2007 4:06 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1941-53 235s (except 53 Power Glide) had splash oil.
