| | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | 235 will only run with choke close,but with gas tank half full runs much better than full tank. but still fully choked.I checked for vacume leaks carb manifold vacume lines none.new filters gaslines tank gas cap is vented.cold it be my fule pump,pump is rather new or vacume advance.thanks | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, old chevy, the carb is dirty on the inside. It needs to be removed, taken apart , all the removable jets taken out and put in a carb tank to be cleaned.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That's what it sounds like to me too. Trash in the jets. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Hey oldchevyguy. Have had a issue the same as yours. Takes a little trouble shooting. But here is a few ideas.
First remove the fuel cap and run it and see if that helps. If not continue on.
1)Remove the fuel line from the carb and the fuel sending unit. 2)Remove the fuel sending unit from the tank. 3)Check the screen on the fuel sending unit (remove and replace if plugged). 4)Blow the lines out backwards and if you need run some mechanics wire threw it. NOTE: DO NOT BLOW LINES OUT WHILE STILL HOOKED UP TO TANK If all is clear then you know the lines are clean (mine were packed full of rust and I just cleaned them out this way). Blow the sendin unit out as well (mine needed replaced). 5)Inspect inside the tank for rust. (Clean, Repair or Replace as needed)
6)If there is rust found Clean all well and assemble. Run the truck. If this dose not help then there may be rust sucked in the carb.
7)If no issue is found here then continue to trouble shoot the carb.
Good luck with your quest | | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | i have a new tank new sender new lines .whith the old tank i hade 2 filters to carb.i opend bowl it looked clean.i will clean carb jets i know someone who has cleaning tank .thanks | | |
