| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I have a 1975 350 that is built basically stock that I have in my 1964. I am putting it back together and making a few changes. One of which was putting a 1970's cast iron intake (4 barrel). My problem now is that because of the older intake I don't think the existing alternator brackets are going to work. To make matters worse the photos that I did take of the motor with the original intake were lost when my computer crashed. Does anyone have photos of how this hooks up? | | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | I have a 1974 454 and a 1985 350 I could take some pics of if you think that will help and let me know just what you are interested in.
1949 Chevy 4400 216
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I saw a rat rod today with an alternator bracket that bolts to the water outlet rather than the manifold. He said he thought it came off a '73-74 Camaro. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Here you go. Note how I painted the parts different colors so you could get a good contrast.  That is a 1974 GM truck setup. | | |
