| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I pulled my rear windows out and have begun sand blasting the body on my burb. Unfortunately, the exterior window frames were filled with bondo and are filled with holes! I currently have an ad on the Parts Wanted section looking for these parts.
My question is. Has anyone tried to repair (fill) the holes with any luck? Any other ideas on repairs / replacements.
Thanks, Cory | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If you know an expert tig welder, you could buy some front door frames and have the welder piece in the damaged areas. Probably the only way to get new metal into the old shape. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Has anyone actually done the repair using front door frames? If so, do you have any pointers on how to get this done.. Thanks PS still looking for some replacement frames  | | |
