0 members (), 100 guests, and 4 robots.
Topics128,261
Posts1,058,346
Members48,485
So here's the question. I want to run my stock axle and front suspension on my 1 ton panel. I've searched the site and frankly the volume of results is overwhelming. Does anyone know of a part number or make/year/model power steering gear box that will bolt directly in place of the stock box? It would be great to know the correct pitman arm as well. I will be replacing the stock steering column with an ididit tilt column that will be installed at the same angle as stock. Thanks for any input you might have. Michael.
No such thing...
Some fabricating and or store bought brackets are necessary.
•1952 Chevrolet 3800 pickup
---All pictures---
Yeah, thanks. I am well on my way. Bought a used saginaw box for $45 and a bracket/steering arm kit from CPP for $119. We shall see if the pitman arm works...
Moderated by  Dusty53
