3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
#835397 03/15/2012 4:15 AM
Hello, I recently bought a 1946 Chevy Truck and I posted a topic on here to get help painting the chevrolet letters on the upper grille. To my surprise when I removed the upper grille I saw the radiator support bar and it was broken. They put a splint on it to hold it in place. I found a support bar on eBay and purchased it. The problem I am having now, is the support bar should be held in place by 2 bolts one on each side, but there is no bolts installed. Their is nothing that I can see holding the support bar in place but it does not want to come off, is it welded in place? What can be holding in place? And how can I go about removing it to install the one I got on eBay?
Existing Radiator Support Bar
Existing Radiator Support Bar Splint
eBay Replacement Support Bar
eBay Replacement Support Bar Bolt Hole
1946 Chevy Truck Export Blue with Black Trim
yes it'll be welded on the ends, you'll need to pull the rad and rad support to replace that
That is not what I wanted to hear.
