1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, I recently bought a 1946 Chevy Truck and I posted a topic on here to get help painting the chevrolet letters on the upper grille. To my surprise when I removed the upper grille I saw the radiator support bar and it was broken. They put a splint on it to hold it in place. I found a support bar on eBay and purchased it. The problem I am having now, is the support bar should be held in place by 2 bolts one on each side, but there is no bolts installed. Their is nothing that I can see holding the support bar in place but it does not want to come off, is it welded in place? What can be holding in place? And how can I go about removing it to install the one I got on eBay? Existing Radiator Support Bar Existing Radiator Support Bar Splint eBay Replacement Support Bar eBay Replacement Support Bar Bolt Hole
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it'll be welded on the ends, you'll need to pull the rad and rad support to replace that
Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | That is not what I wanted to hear.
