1 members (baldeagle),
34
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | recently purchased a 48 CHEV 3/4 factory flatbed truck. I have the opportunity to purchase a 1989 light duty 3/4 ton chev. thinking I might like to put the complete diff under the 48, and try to adapt the frt disc brake system along with the dual master cylinder. any thought,s suggestion,s or advise ? THANK,S DOUG
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48, there are a couple of ongoing discussions here on the subject of disc brake conversion of the front axle, one in the "Big Bolts" forum, and one in the "Tons o fun" forum. As to the rear axle, you will probably have to relocate the spring pads, but should be a fairly easy swap, I imagine the track is wider on the new rear axle, so as long as that is not a concern go ahead with it. Don't forget about your pinion angle. Have you seen the B.C. Bolters forum further down the page, there are quite a few of us on here. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I bet that axle is going to be somewhat too wide, even for a flatbed. Measure the track widths to see how different it is.
My dad bought an '88 light 3/4-ton 4x4 brand new, then passed it on to me several years ago. I've since sold it - the vehicle was always something of a lemon, blowing up a couple of transmissions and transfer cases, along with numerous sections of the electrical system, within less than 100k miles of mostly garaged and very well-maintained service. My personal opinion would be to find a better starting point for conversion parts. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | When you say "light duty," what do you mean? Is it a 3/4 ton with the semi float 8 lug rearend or the 6 lug rearend? If I recall, they had both back then. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | white dog, it is a semi-float 8 lug. havent measured the width yet. I have available a 74 full float diff. this one is a 14 bolt, would this be a better choice ? thank,s Doug
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The semi-float would be alright. They are plenty strong and lots of parts and available gear options. If I remember right, the semi float is a little narrower than the full float 3/4 ton version. The full float would be a good choice too, since you have a flatbed and no fenders to worry about. If you wanted to narrow things up a bit, you could find some dually hubs and install them on the full floater. Of course, you'd have do some modifying on the brakes. Some B350 Dodge vans used a wheel with more backspacing, you could use them to narrow things up a bit too. As far as the front brakes go. There is no definative solution yet. Grigg, myself, and some other members are working on something that will work on the 3/4 and 1 tons. I would definately hang on to the master cyl. and booster, you may be able to do something with it later. Chris BTW, I have a 67" full float and a 63" full float. Check out the pictures at www.photobucket.com/whitedog76pics
